Cold starting
Cold starting
Does anyone know if there is a cold start circuit on the 1150R. Mine does not want to fire in the morning. It takes quite a bit of cranking to get it going. After the bike is warm it fires up right away. All other operations are normal. Any information would be welcome.
Re: Cold starting
Forgot, 2004 with 17,000 miles.
Re: Cold starting
I presume that you are using the "choke" by the left grip....two positions, the first about half way up, has a stop, the second position, up from the first position is spring loaded and must be held to start a cold engine.
I pose the question because you don't make any mention of it on your post.
Re: Cold starting
Ahhh the tricky hold it up switch. No I was appearently just going to the first position. Thanks.
Re: Cold starting
When cold out, mine seems to need a little throttle to get it to start.
Buckster '03R
#543
#543
Re: Cold starting
A battery tender and new plugs make a very positive difference on cold mornings.
Re: Cold starting
Dont forget your oil is thicker when cold and therefore takes more cranking power to turn over the engine. With temps in the 30'sF or lower I have had good luck warming the oil with a trouble light sitting near the oil pan for an hour or so before my ride.
