need specifically stock fog lamps! as mine don't turn on! did all the usual fuse, bulbs, switch change out still can't turn on, I have followed wiring going into main wiring loom from switch but lost wiring their! Grounds are OK? as main headlights are Ok.
I know their is wiring diagrams are on some CD-rom but for @ $75.00!
need wiring diagram for 2004 R1150rt
Re: need wiring diagram for 2004 R1150rt
Actually, I think my official electrical schematics CD-rom cost about $125.I know their is wiring diagrams are on some CD-rom but for @ $75.00!
Give me a few days and I'll check the RT fog lights circuit. No I cannot and will not copy the info.
PM me with your email for a couple of screen grabs.
Looks like there's a separate fog lamp relay for 2004-2006 R1150RT (R22).
Power is supplied through main harness and load relief relay, then to fog light switch, then fog lamp relay, then direct to fog lamps.
re: fog lamps not working
I asked about wiring diagrams here on board, one member did sent part of diagram, thanks to him, I used v.o.m. meter on relay plug in block, no power so I pulled bottom off of fuse/relay tray and found 2 wires/power for fog lamps had "burned off" of relay plug in plastic block melting it on bottom side, since I had donor/wrecked RT m/c I cut that good relay plug in block off and spliced into this m/c wiring harness!
Needless to say my fog lamps now work!
About a 2 hour job, The R1150RT maint. manual shows dissassembly of fuse/relay box bottom for access very well. as their is 2 hidden screws on inside of rear fender well. The hard part was getting the relay plastic block to release for removal from bottom of box, cut one plug short the other long so one has some wire to work with on the MS aircraft crimp slices.
Thanks to all again.
