Handlebar raisers
Handlebar raisers
Does anyone have any comments on this? Raising the handlebar and moving it back. Are there many types and anything that I should avoid?
Re: Handlebar raisers
There are many types and it depends on what are your specific needs, most of them do not affect any of the cabling or brake lines. See the link below for some different options............
http://search.ascycles.com/motorcycle/Bar%20Backs
I purchases these for my bike and they worked out great!
Here the link:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... _717wt_732
I put the Verholens on mine. You sit up straighter, but you are in the wind more at freeway speed.
Very nicely made but expensive.
Here is a link to a picture of them
Brian
Brian
Did you have to change cables for the Verholens?
No, all the cables and hoses are long enough. I did rotate the bars up a little, so I had to reposition both lever assemblies.
Brian
Brian
chitownrbike
Be careful on the ones that bring the bars "back" and not just up.
It will change your steering enough to make a difference as the bars will no longer be in a line up from the forks..
caveat emptor~
caveat emptor~
I had MotoTechniques risers on my 2004 1150R. They come in two sizes and I believe I had the 1 inch up and 1 1/4 inch back size. No trouble with cables, except you do have to re-route the throttle cable to outside of the the headlight bracket. No big deal. Also, I couldn't tell any difference in how the bike handled. Just more comfortable.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
Ogden, Utah
2002 R1150RT
2004 R 1150GS
I went the same way as awagnon. The alteration was fine. No cable changes, but I cut a couple of zip ties and re-did them to make sure cables were loose enough. It's a small change, but well worth it for long rides. Relaxes the forearms a bit and makes the back straighter. Mine are off at the moment, but going back on soon.
Verholens for me, as well. No cable issues, & as said, just had to rotate the controls slightly.
The resulting riding position suits me, at 6'-2", but it is a personal thing.
Martyn Hillier, Cheltenham, UK.
1979 R100RT, 2013 R1200RT, 2014 R1200R & 2016 R1200RT Iconic.
I find that VARIO by MFW are the best.
http://www.mfw-wolf.de/en/products/vari ... ebar-riser
I got mine from http://www.twistedthrottle.com
I don't see them offered by that site anymore, but they are listed as MFW dealer in US.
Give them a call.
Good Luck.
Give them a call.
Good Luck.
Lifetime Member #586
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
2004 R1150 ABS
2003 F650 CSA
I will hopefully soon add SWMotech risers on mine: 1" up and 1" back. I'll give a review. Any negative feedback on this type out there? thanks.
2002 R1150R black
I fitted the mototech risers a few days ago without any refitting of cables or hoses. I find the bike to handle even better than before and the position is more relaxed. Just perfect.
I've finally put some miles on with the SW Motech risers. They are 1" up, and 1" back - they just go out diagonally.
I think they detract from the naturally good handling of the bike for me. I remember trying an R1150R with a Gen-Mar ones, I believe, and I think they were 1" up and 1.5" back, but they felt great. I know this makes no sense to me. I am just a little disappointed. I thought the current ones I have would make ride more comfortable and not affect handling.
I feel like I am using the handlebars more than I should, rather than using my body to lean. Maybe I need more time out there with the new posture. It was easier being that much over the bike as it was before. Anyway, I just thought I'd add my opinion.
George
George
2002 R1150R black
+1 on the Verholens, though they are expensive - they look the best, IMHO. I'm 6'1" and combined 'em with a footpeg lowering kit, for just about the perfect riding position.
Craig
'02 R1150R - second time around after 8 years away
'85 BMW R80 - I have a thing for Airheads
- Ol' Jeffers
Verholens going on on Friday! If the bike is more comfortable then the stress is reduced. And at my advanced years
I should be able to reap some benefit.
OJ........everybody's pal!!
http://www.moto-techniques.com/061062.htm
Those are the ones I used, fit very nicely, reasonably priced,
no cable problems. I did loosen some of the zip ties like many
folks have done just to avoid problems with the wires at a later
date.
I had first tried some from A&S that were "fancier" but they didn't
fit the bar diameter. They were more rounded and looked somewhat
like the Verholen's. At least A&S was nice enuf to provide a
refund no problem. I looked but don't see them on their now.
date.
