f800gs mirrors for the r1200r
Ric
Re: f800gs mirrors for the r1200r
Post by Ric »
ThX for the info RadRider !
Installed my Barkbusters Storm handgaurds and Kaoko cruise control tonight.
Everything went as smooth as discribed. All looks great !
Can't wait to get out on the road to try it all out.
ThX again !!!!
10 R1200R
09 KLX 250sf
74 H2
77 RD
69 Kawasaki Bushwacker
67 Kawasaki 120SS
65 CB 450 Black Bomber !
BigEasy
Post by BigEasy »
RE: Storm Guards. I just put a set on my R today and they work fine. Just be careful of the bracket orientation. I thought mine were fine, but just moved my bike under a canopy where I'm staying and the left side brackect gouged the paint on my tank #-o that's gonna cost me. CR@P
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
FredRydr
Post by FredRydr »
I don't understand this.
I have both a 2007 R1200R and a 2009 F800GS, and an extra pair of F800GS mirrors. I want to move those mirrors to the R1200R. I tried threading the F800GS clamps into the R1200R brackets, but the threads are a different size. (I suspect the R1200R brackets changed after 2007, allowing for a friction fit mirror stanchion, instead of a threaded stanchion.)
Can anyone guide me here?
Thank you.
Fred
'07 R1200R
'09 F800GS
Coyote Crazy
Triple Lifer
Donating Member #: 723
Post by Coyote Crazy »
FredRydr wrote:I don't understand this.
Thank you.
Fred
'07 R1200R
'09 F800GS
Fred,
Sorry to hear you are having difficulty installing the F800gs mirrors. I ordered and picked up my F800gs mirrors p/n 51167715861 & 51167715862 2 weeks ago and got a little worried reading your post as if they would work on my 2007, so I made a bee line for the garage to do the install. I removed the OEM mirrors with a 14mm wrench, took a small effort due to the fact the clamps were installed with Loctite. The new F800gs clamps threaded in both sides by hand finger tight with new Loctite applied and required a quick snug with a 17mm wrench. Slipped in new mirrors, snugged clamps and slid down rubber covers. Total time 10 min. My R1200R was built 02/2007 so I do not believe the model year is the issue. Might want to check and see that the threads in the brackets are clean of any Loctite. I wish I could be of more help to you, but I don't think the model year is the issue here.
Rick B. - Santa Clara River Valley, CA
Iron Butt Member 54010
2007 R1200R Crystal Gray
FredRydr
Post by FredRydr »
My apologies. Today, everything threads together as was explained. After careful consideration, I have to conclude that one of two scenarios applies:
(1) my motorcycle was haunted that Halloween night I was trying to thread the parts, or
(2) I was screwing the GS' mirror clamp into the R's reverse-threaded adapter.
Hey, it was cold and dark out there in the garage. So it must have been (1)!
Fred (ordering the parts)
Coyote Crazy
Triple Lifer
Fred,
I know what you are saying… some days!
Either way glad to hear all worked out.
Enjoy your new view to the rear!
xprof
Donating Member #: 617
Post by xprof »
And enjoy just looking at them as you drive. You know, mirrors are one farkle that are always in your view, and mine just continue to give me pleasure on every ride (a 350-miler yesterday, up to Atascadero, Hwy 41 to Cholame, down Bitterwater Road, then the length of Carrizo Plain on 65mph dirt, and back over Pine Mountain Summit, Hwy 33 to Ojai, then Hwy 150 over Casitas pass)!
Mike in SB
2009 R1200R all black
ex1970 BMW R60/5
ex1959 BMW pre-slash R60
ex Matchless G80CS
tobes
Post by tobes »
xprof wrote:And enjoy just looking at them as you drive. You know, mirrors are one farkle that are always in your view, and mine just continue to give me pleasure on every ride (a 350-miler yesterday, up to Atascadero, Hwy 41 to Cholame, down Bitterwater Road, then the length of Carrizo Plain on 65mph dirt, and back over Pine Mountain Summit, Hwy 33 to Ojai, then Hwy 150 over Casitas pass)!
That's a great route. Have you ridden Soda Lake Road? That's one dirt road I've been wanting to explore but haven't yet.
Mike
xprof
Post by xprof »
Not on my bike, but by car. I see no reason not to try it by bike, but I'd go a little slower to avoid surprises (and so as not to run over snakes...).
Mike in SB
ex1970 BMW R60/5
ex Matchless G80CS
xprof
Post by xprof »
Oops, my bad! Soda Lake Road is the road that I took, easy flat 65mph dirt. No problem at all! I mistakenly thought you meant the road on the other side of Soda Lake, which is Elkhorn Road. It is a bit "dirtier", with some steep climbs and some dry washes, but I have driven it in my Prius, which has only about 3" of ground clearance, and had no problem. You could drive up Soda Lake Road, cross over north of Soda Lake, and return via Elkhorn Road, if you are feeling adventurous. April and May are good months for the Carrizo; good wildflowers, snakes, and you might see some pronghorns. Stop at the visitor center at the north end of the lake for good local info. Take the tour of the Painted Rock if you can spare the time, and drive up to the Soda Lake Overlook for some pix. Enjoy!
Mike in SB
ex1970 BMW R60/5
ex Matchless G80CS
tobes
Post by tobes »
xprof wrote:Oops, my bad! Soda Lake Road is the road that I took, easy flat 65mph dirt. No problem at all! I mistakenly thought you meant the road on the other side of Soda Lake, which is Elkhorn Road. It is a bit "dirtier", with some steep climbs and some dry washes, but I have driven it in my Prius, which has only about 3" of ground clearance, and had no problem. You could drive up Soda Lake Road, cross over north of Soda Lake, and return via Elkhorn Road, if you are feeling adventurous. April and May are good months for the Carrizo; good wildflowers, snakes, and you might see some pronghorns. Stop at the visitor center at the north end of the lake for good local info. Take the tour of the Painted Rock if you can spare the time, and drive up to the Soda Lake Overlook for some pix. Enjoy!
Awesome. Thanks for the info.
Mike
