ipekur wrote:I have R1100R 1998.
Recently my gas tank started leaking gas from under the seal of the gas pump/filter cover (it is on the inside of the tank).
When I took of the nuts and replaced the seal one of the bottom studs (one of 6) fell off!
I took it to the dealer and they laughed and said - get a new tank ($1000 !!!!).
What can I do? any advise would be greatly appreciated! It spring and I need riding time!
Thanks!
What your stealer says is rubbish. A good advice from the land of oilheads:
http://www.powerboxer.de/tank-sitz/181- ... abgerissen
- clean the area where the stud "fell off" (the stud is welded to the tank from the inside)
- have kitchen paper with grease inside the tank to catch any metal chips while drilling
- drill through the hole with an appropriate drill to get a clean and even hole
- cut a thread
- use a screw of appropriate length and dia and screw in from the inside
- fix and seal the screw from inside using UHU Plus or some other epoxy based glue (fuel resistant)
- attach the plate with the fuel pump/filter and your done
The second pic on the German site gives you an idea. Click on the same to get a larger version.
It is worthwhile mentioning that the plate must be fixed using all 6 studs, otherwise a leak may occur.
Brgds
