Connecting spot lights to dip switch
johngellis
Post by johngellis »
Just bought some Denali spots and mounts from Revzilla (20% off this weekend).
I want to be able to switch the lights on and off using the headlamp dip switch. Where is the best place to pick up the high beam wire to splice in the controller to the new spot lights. (2004 R1150R)
sweatmark
Septuple Lifer
Donating Member #: 208
Re: Connecting spot lights to dip switch
Post by sweatmark »
johngellis wrote:Just bought some Denali spots and mounts from Revzilla (20% off this weekend).
So you want the Denali LEDs to turn on when you select high beam? Or do you have a kit with separate switch and relay that requires an ignition ON source as master power control?
There are lots of wiring options for either case.
