blowing fuse 5
thejavelin
blowing fuse 5
Post by thejavelin »
04 r1150R with 11k miles
I am blowing fuse 5 and I found a melted wire by the starter. The wire was routed behind the starter, individually covered, and it is a brown 18ga wire with a light green stripe. I don't have a wiring diagram so I need some help figuring out where it goes and if it is related to my fuse issue.
InvisibleOrdinary
Re: blowing fuse 5
Post by InvisibleOrdinary »
Check out this video… somewhere past about 1/2 way, Chris explains the wires behind the starter. And you can find the wiring diagram in here: http://home.mindspring.com/~jabrooks/
good luck.
Dave
peels
Re: blowing fuse 5
Post by peels »
thejavelin
Re: blowing fuse 5
Thanks guys. I don't think the video link is there but I am going to dig into this diagram this weekend.
thejavelin
Re: blowing fuse 5
I traced it straight to the ECU. Replaced the ECU and it is back up and running. Thanks
