where to buy the small flat washer on the oil drain plug?
FM696969
Post by FM696969 »
who sells the flat small washers on the drain plug besides bmw?
Post by DJ Downunder »
Just re use the old one...it will be ok....or buy the genuine one...I think that's your only option.
Kazushi
Re: where to buy the small flat washer on the oil drain plug
Post by Kazushi »
Just ask your BMW mechanic for one or two... Last time I asked, I got a handfull of them (they were probably oem)... :wink:
FM696969 wrote:who sells the flat small washers on the drain plug besides bmw?
apaulcopy
Post by apaulcopy »
My dealer always tapes a new washer to the oil filter box. I'm sure a dealer will give you a bunch of washers cheap, if you want to use another brand filter. Be aware that the stock washers are "crush" washers that are made of a soft alloy designed to compress when the drain plug is tightened, creating a nice, tight seal. For this reason, I would avoid re-using a washer if possible (okay, I admit, I've done it in a pinch). I would say getting some stock BMW washers falls under the category of "cheap insurance."
R4R&R
Donating Member #: 293
Post by R4R&R »
I've always had to buy them - at the dealer. I typically get a couple when I'm buying my oil filter.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
mnnden
Post by mnnden »
I really should, (as I get one with every filter) but I rarely change mine, I think I have 3 or 4 oil changes on this one. Den
We all gave some,
Some gave all.
Anonymous
daslimpet
Post by daslimpet »
mnnden wrote:I really should, (as I get one with every filter) but I rarely change mine, I think I have 3 or 4 oil changes on this one. Den
I've got the same washer too. Hasn't leaked a drop in 7 oil changes.
:roll:
"Never ascribe to malice that which is adequately explained by incompetence" - Napoleon Bonaparte
