Oil filters and fuel fillers
single650
Post by single650 »
Two technical questions:
Does a K oil filter tool fit a Rock?
Has anyone taken a saw to that stupid tube inside the fuel filler. The K had a similar tube but you could remove it as it was screwed onto the inside of the fuel filler. Removing means you can see into the tank when filling and you get about 2 litres (1/2 US gallon) extra fuel in.
'03 R1150R Rockster
'94 K75s
lacrimosa
Post by lacrimosa »
Make sure that you don't overfill your tank, hot weather may cause the fuel in the tank to become more volatile, causing higher pressure in your tank.
The pressure in your tank will rise and the safety valve will open, spilling that extra gallon...
R1150R Rockster
riceburner
Post by riceburner »
lacrimosa wrote:Make sure that you don't overfill your tank, hot weather may cause the fuel in the tank to become more volatile, causing higher pressure in your tank.
Actually the pressure won't rise because there's an air pathway out via a tiney hole in the filler cap - all bikes have this (it's what makes the whistle noise occasionally). Providing you don't BRIM the tank completley (and you'd be a fool to do that anyway) you'll be fine. :)
Non quod, sed quomodo.
A Rockster Life
Neil
Donating Member #: 918
oil filter tool
Post by Neil »
The BMW tool I had for my R1100RS fited my K1200RS and allso my ROCKSTER
single650
Post by single650 »
To answer myself... it's the same filter on oilheads as bricks, so same tool
'03 R1150R Rockster
'94 K75s
