I’ll be changing the final drive and transmission oil.
Any reason to use something other than the 90 wt. GL5 Hypoid gear oil called out in the manual? Synthetic?
Gear Oil Choices
Tundra Dweller
Gear Oil Choices
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
2008 Suzuki Bandit 1250
2013 BMW GS 650 Sertao
1975 Norton 850
2002 BMW R1150R
Re: Gear Oil Choices
Use the regular heavy stuff. Synthetic makes for a lot of noise. I tried it thought my trans had gone bad, called my dealer friend and he said right away get the synthetic out and use 90wt. Hypoid, period. Noise was gone after the change back. These are very noisy to begin with. FYI- The Red Line stuff doesn't work either.
02R1150R,02R1150Rabs,04R1150R
02R1100S,05R1100S(BCR),
(2)-S1000XR
IBA#7147
IBA#7147
Tundra Dweller
Thanks Swamper. It shifts well with Dealer gear oil in it. At just under 10,000 miles it should only get better.
I'll get a couple quarts of 90 wt. Should be enough for both the tranny and final drive. Cheers!
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
I use (IIRC) Castrol 80W90, but then I'm in the UK, it doesn't get quite as warm here.
you need 'just' over a litre, if I remember correctly, it's something like 1050ml that you need in total (1.05 litres)
I use 80W90 Castrol w/no additives. change once a year regardless of miles unless been riding dirt a lot then always change after return to the barn.(regardless of miles.).
mike Mojave CA
'04 ROCKSTER
'04 ROCKSTER
Tundra Dweller
Thanks, I do live a few hours from Canada so no extreme heat here either.
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
