R1150R Indicator Lights flashing erractically
Can anyone help? My R1150R turn signal indicator lights work fine. After a while of riding they suddenly blink quicker and sometimes revert to the normal flashing speed. Whats up?
DJ Downunder
- Nakigara
Same thing happened to me. I replaced all of the bulbs to no avail. I decided it must be the relay and popped the seat off to look. With the engine not running, I turned on my blinkers and started pulling relays until they quit. When I put the relay back in, the blinkers were fine. The relay had just come loose or there was some intermittent contact going on. Everything is still fine more than six months later!
Dan
Dan
Thanks DJ and Dan.
As suggested, checked the globes. All were fine.
Removed the flasher relay (boy, is removing that fastner around the relay tricky!). Cleaned it with Philips contact cleaner and replaced it.
Took it for a short ride and everything seems fine.
Will take it for a longer ride soon!!
Thanks again guys!
Thanks again guys!
Re: Indicator Lights flashing erractically
Was this the problem?triumsg wrote:Thanks DJ and Dan.
Thanks again guys!
Signal Relay Connector
Rod
Apple Macintosh
Apple Macintosh
