I know this topic has been discussed before, but with the rapidly rising prices thought I would ask again. Some anaylsts predict $10 gal regular within a couple of years.
Thanks!
A very good point, trying to save $ on gas and then paying a high repair bill.def38 wrote:While I ride a GS model, here is my recommendation regarding fuel selection;
1- Buy only from stations that maintain their equipment and turn fuel over frequently.
2- Use only the recommended octane fuel for your model. Running lower than recommended octane risks detonation some of which cannot be heard and if allowed to continue can lead to top end engine damage with resulting high repair costs...not worth the risk IMO.
3- Remember, our boxers are air/oil cooled which means combustion chamber temperatures are higher than similar power liquid cooled engine designs. By design, boxer combustion chambers run hot. Heat is your enemy. Combustion chamber temperatures skyrocket when detonation occurs. This heat, if unabated, can melt pistons, cause ring failure and cook your engine oil.
Here is some interesting reading on the subject of our boxers fueling and FI adjustments...boxermania wrote:Topic well discussed on this forum.....I'll share my experience without getting into the technical aspects, if someone has specific questions I'll do my best to answer.
First let’s understand the following
Assumptions
The bike has to be in a reasonable state of tune. In our bikes the TB sync is one of the major out of tune contributors....
Operator doesn't lug the engine
Facts
One gallon of gasoline has a specific caloric value (BTU's) and it is the same irregardless of grade, what changes is the additive package
Gasoline formulation varies according to region
Ethanol decreases the caloric value of gasoline, hence less power and less MPG
All engines of the same family are not the same as they are mass produced. This is included as a clarification and is especially applicable to the recurring issue with surging of the oilhead modules. In the case of my bike, if there was any surging. it was never detected.
I have always been the proponent of using the lowest gasoline grade that the engine can be operated with, see above. In my last two bikes, a 02 BMW R1150R and a 98 Suzuki Bandit 1200S, both modified for additional output I used regular, 87 grade gas with no problems whatsoever.
So that being said, it is upon the operator to evaluate what they have and how they operate the vehicle and decide on the fuel grade to use.
One last tidbit of information that could save you some $$$$, if you find that regular grade won't work, try running a tank of half regular and half mid grade and see how that works for you.![]()
You will find ethanol in all grades of motor fuels throughout the US. In some areas, you will find E85 fuel used in FFV equipped vehicles. E85 is 85% ethanol, 15% gasoline. Do NOT use it in your BMW...it will not run.cworley5150 wrote: There is even a local station that has 92 octane as their premium and that is the worst fuel I have ever ran in my bike. It really pings with that stuff. I don't buy gas there anymore, but I will have to check and see if there is any ethanol content in their fuel. It really sucks.
So, what is your point? What should we use for fuel? Which grade (octane)?toolinalong wrote:Ladies and Gentlemen,
I am increasing my contribution from 2 cents to a nickel.
All this talk has made me want to do some more research. And I have decided that my previous comment, wherein I stated that stepping down a grade may be ok, may have been a bit too kneejerk of a reaction to the question, as it was based solely on my own experience up here at lofty altitudes. Now I think that other factors need to be considered.
My bike is a 2002. A few musings:
1. My manual says: Refuel only with super (premium) grade fuel to DIN 51607 standard or equivalent, minimum octane number 95 (RON) or 85 (MON), AKI 91 Premium
2. Using the U.S. octane rating method of R+M/2 translates to 95 + 85 = 180/2 = 90, which thus is the manuals minimum called for octane rating for the bike (it does not specify, so one assumes that it assumes you are at sea level).
3. Front Range Colorado (elevation 5000-9000 feet) gas is lower in octane then at sea level (see below), so our 87 octane (which is what I have been using) mid-grade works the same as the 91 octane at sea level.
4. The underlying reason for this seems to be that the higher altitude (and thus lower atmospheric pressure) effectively lowers the actual compression ratio achieved within the engine, therefore less octane is needed to avoid knocking (pinging).
5. I have put 67000 miles on her. At 42 mpg (my guess for my overall mileage) I would have burned 1,595 gallons of gas so far. At a 10 cents per gallon price differential (again the normal around here) I would have spent $159.50 over the 6 years of riding it, or $ 26.67 per year if I had been buying premium. The cost of dinner and a few beers at my favorite local pub.
6. When I road trip, I always buy mid-grade, which means in lower elevations I am buying 89 or better octane fuel.
7. In the early days of ownership when I was still learning how to properly ride the bike (and was using premium), it would sometimes ping when I was going uphill in the narrow, steep (10% grade) part of the canyon road I take every day to work (in season of course). Learning which gear I should be using in order to keep the revs up and be at the speed I wanted to be at eliminated that.
8. There is so much information on this topic all over the internet, but I liked this one for it's clarity, even though it is wikipedia: http://en.wikipedia.org/wiki/Octane_rating
9. An excerpt from that article:
In the Rocky Mountain (high altitude) states, 85 octane is the minimum octane and 91 is the maximum octane available in fuel. The reason for this is that in higher-altitude areas, a typical combustion engine draws in less air per cycle due to the reduced density of the atmosphere. This directly translates to reduced absolute compression in the cylinder, therefore deterring knock. It is safe to fill up a car with a carburetor that normally takes 87 AKI fuel at sea level with 85 AKI fuel in the mountains, but at sea level the fuel may cause damage to the engine. In some east coast states, up to 94 AKI is available [5]. In parts of the Midwest (primarily Minnesota, Illinois and Missouri) ethanol based E-85 fuel with 105 AKI is available [6].
California fuel stations will offer 87, 89, and 91 octane fuels, and at some stations, 100 or higher octane, sold as racing fuel. Until 2003 or 2004, 92 octane was offered in lieu of 91.
