R1150GS Panniers on a R1150R ?
fazer1k
Post by fazer1k »
Are the GS panniers the same design/model and will they fit without any problems on the R1150R ?
MikeCam
Centurion Moderator!
Donating Member #: 100
Re: R1150GS Panniers on a R1150R ?
Post by MikeCam »
They are a straight interchangeable fit. Frame and pipe location are identical.
The RT/RS will also once the pipe is lowered and the foot extended. This gives you the full size both sides.
fazer1k
Post by fazer1k »
MikeCam wrote:They are a straight interchangeable fit. Frame and pipe location are identical.
Thanks for the quick reply Mike, looks like I can now safely place a bid....
Cheers
ruddy
Post by ruddy »
In fact, the GS bag mounts will also fit the R.
Rick
2003 R1150R: Silver
Lifetime Member #585
fazer1k
Post by fazer1k »
Managed to get hold of a couple of good panniers at a great price, however the lock is broken on one of them. It's the plate that turns around with the key which then prevents the handle from moving/opening.....I guess replacement parts are available to repair ?
