I have a Garmin GPS on my '03 r1150r which I charge through the auxiliary power plug. I have the audio from the GPS routed through my autocomm system so I can play music, etc from it.
The problem is, I get a bad alternator noise through the headphones when the unit is plugged in to the auxiliary plug. this noise goes away once the power is disconnected.
So....not knowing anything about shielding / signal integrity / etc, I need help. Can anyone recommend a fix to make the noise stop ?
Which Garmin do you have? We use the 2720, which Autocom has a specific Autocom cable adapter. You are right is suspecting shielding, the Autocom cables are shielded. I have a complete system from Autocom including MP3, GPS, BTB, Cell and pillion, a do not have an issue on my 04 1150R.
I would suspect you are getting noise from unshielded cables or two grounds feeding the same equipment.
Try wiring to the battery directly using an in-line fuse. I have everything running to switched Centec fuse panel located next to the battery. See if that eliminates the whine noise.
