Never heard of this stuff until a few minutes ago. Very leery. Anyone?
Klotz Octane Booster is a concentrated tetraethyl lead substitute formulated to increase the MON octane rating of gasoline up to 10 numbers. Helps eliminate engine damaging detonation, spark knock, pre-ignition, and pinging from low octane gasoline. Octane Booster modifies the burn speed and flash point of gasoline to create a stable combustion chamber flame front, maximizing performance and power. Stabilizes oxygenated and ethanol enriched gasoline to prevent lean-out conditions. Klotz Octane Booster provides needed upper cylinder lubrication that is missing in unleaded gasoline. Klotz Octane Booster will challenge and outrun the competition in the following ways:
* Raises MON octane rating up to 10 numbers
* Improves throttle response and acceleration
* Prevents pinging and spark knock
* Stabilizes oxygenated and ethanol enriched gasoline
* Absorbs moisture in fuel system
* Preserves gasoline up to 16 months
* Eliminates gum and varnish build-up
* Catalytic converter safe
* O2 sensor safe
* Lead substitute
* Fuel injector cleaner
Application:
For use in all 2/4-Stroke gasoline engines.
Characteristics:
Product Color: Green
Instructions:
Compatibility: All gasoline, synthetic lubricants and petroleum oils. Will help blend lubricants and oils with gasoline in extreme temperatures.
Octane Booster: 1 oz. Octane Booster per gallon of gasoline will raise the octane by 2 ½ numbers. For optimal performance match the octane to the engines compression ratio. Use octane index A.K.I. and R+M/2. Octane Booster is effective in inverse ratios to the octane lev
Gasoline stabilizer: Preserves gasoline during storage. Add 1 oz. Octane Booster per gallon of gasoline for 6 to 8 months, or 2 oz. per gallon of gasoline for 12 to 16 months.
Fuel System Cleaner: Add 16 oz. Octane Booster to gas tank treats up to 20 gallons of gasoline.: Protect painted surfaces, wash off immediately with water to prevent damage. Will not harm catalytic converters.
Available part numbers: KL-602 16 oz.; KL-628 gallon; 30 & 55 gallon drum
Klotz Synthetic Lubricants, Inc. • 7424 Freedom Way • Fort Wayne, IN 46818
[email protected] • Phone: 260 490 0489 • Fax: 260 490 0490 • Visit KlotzLube.com
Mastering the Science of Synthetic Lubrication® Since 1959
waynemathews
- Triple Lifer
Re: Klotz Octane Booster
I can't speak to all the claims, but it does work as an octane booster.I know several folks who use it in their race boats and hot rods. I don't see much use for it in BMWs; its a bit pricey compared to premium gas or other fuel stabilizers. Unless the rumors of Don E's 200 HP turbo R1200RR are true
09 R1200R
- blueviewlaguna
Keep in mind that "up to 10 numbers" = 1.0 MON increase maximum, typically these boosters add fractions of an Octane, making the tiny benefit very expensive.
Member# 893
Sander Abernathy
It sounds like a must have...if you are experiencing detonation. I don't think anyone is experiencing detonation in the R1200R though including quite a few people who use regular and mid-grade.
2014 R nineT,
2011 Grey Matte R12R, (at the beach)
2011 Red R12R (RIP), &
'09 White R12R (RIP)
