These two cases rest on three supports.
I believe the two at the top are compatible/identical,
my question is about the one at the bottom,
I believe it is not located in the same position,
being the one in the RT closer to the rear tire than the that of the RR.
If they are not identical, has anybody been able to adapt the bottom support so as to use an RT left case on a R1150R?
Eduardo.
