Dampening dial...
ContraMoto
Dampening dial...
Post by ContraMoto »
The owners manual says to turn the rear dampening dial "in the direction of H or S...". Well...depends on whether "direction" is from the top or bottom of the dial...
Which is "higher" ... clockwise or counterclockwise?
Thnx.
'07 R12R Black w/stripes
North Cali
Tarmac
Re: Dampening dial...
Post by Tarmac »
It's not "higher" it's "harder".
And im pretty certain that it has an arrow on it. Have you tried looking at it?
Tarmac
... where the rubber meets the road
1970 Datsun 240Z
ContraMoto
Yes...harder/higher...softer/lower.
It has an arrow pointing left and right. But on a circular dial, which way is left and which way is right? Normally, you'd think top of the dial determines direction. But the H and S labels are at the bottom of the dial. It just strikes me as unecessarily obtuse, when they could just say "clockwise" and "counterclockwise" to make it clear.
North Cali
rex akro
Post by rex akro »
ContraMoto wrote:It has an arrow pointing left and right. But on a circular dial, which way is left and which way is right? Normally, you'd think top of the dial determines direction. But the H and S labels are at the bottom of the dial. It just strikes me as unecessarily obtuse, when they could just say "clockwise" and "counterclockwise" to make it clear.
The arrows point clockwise and anticlockwise :roll:
Nigel
_______________
06 R1200R
Post by deilenberger »
Imagine it straightened out:
H <----> S
Liam
Donating Member #: 780
Post by Liam »
Turning the screw clockwise, which is equivalent to the bottom of the screw moving to the left makes the damping harder.
