I am having trouble with the gear change on my 1150r, bike has been sat in the garage since October. I took it out for a spin yesterday and it went up through the box ok but wont go back down, I think the pivot bush has siezed. I had to return home using only third and fourth. Whats the best way to remove the clips from the ball joints? I dont want to ping them into some dark corner of the garage.
Hank.
Gear change problem.
- hank
Re: Gear change problem.
These clips are fairly easy to remove. Swing the round part away from the joint and then it is easy to pull the whole thing up. In the 1100 section is a new post with a little picture:
Brgds
Oliver
Brgds
Oliver
- hank
Haben Sie vielen Dank.
- Willfreely
The caption around the service manual and parts upon which they rest is why I relish reading this website; intellectual sarcasm tainted with technical expertise. You're Welcome!
Virginia Beach, Va
2004 R1150R
(past rides)
1983 R80
1981 R100RT
1982 R80
2004 R1150R
(past rides)
1983 R80
1981 R100RT
1982 R80
