Okay, I've been lurking here for a while and now that I've finally landed a schweet R1100R I have some questions to pose to the collective.
The bike is a '99 R model with 85+K on the clock. I bought the bike from a northern Colorado BMW dealer who told me the bike's lineage includes three previous owners all who appear to have taken good care of the bike.
I still have much due diligence to perform but for now can tell you that I've decided to establish a baseline for the bike by changing out all fluids and filters. I'm went with synthetics; 15-50 in the engine, 75-140 in the tranny, and 75-90 in the final drive. I installed a new alternator belt as well. An oil chain dampener from Rubber Chicken Racing is on order as is a fuel filter, quick disconnects, and fuel tank tubing upgrade.
Right after buying the bike I installed a battery tender harness and XM Radio cradle, pics will follow if anyone's interested in seeing what it looks like.
My observations thus far indicate that I need to do the following:
Change out the "buttons" on the front disc brakes;
TB synch, valve adjust, and idle adjustment.
Things I've noticed not working properly that I need to investigate:
A VERY weak neutral light;
A VERY faint alternator light;
Why the starter motor seems not to disengage for a few seconds even after the motor starts;
The bike's propensity to go into a false neutral when shifting from 1st to 2nd;
" " " to pop out of 2nd and either go into a false neutral or drop into 1st;
" " " to exhibit a tendency to make a ratcheting sound when shifting from 2nd into 3rd.
While riding the bike today I noticed that pre-loading the shifter completely solved the aforementioned shifting problems, your thoughts?
I seem to recall an easy fix for the starter unit but for some reason my search skills suck and I can't find it. Yes, I've read a lot of posts about transmission issues but I both invite and need your input.
Aside from all this I love this bike. I bought it for my SO. She's been riding for just over six years and has always wanted a BMW most likely because that's what I ride. It's taken a long time to find the right bike for her because of her height and riding ability. We'd looked at a lot of K75's but found them either a POS, or too expensive, or both. Her new bike, the subject matter of this thread, that is, appears to have had it's seating modified to accommodate a vertically challenged rider. I'm pleased to report that she can flat foot the bike and feels totally at ease on it. That's all I care about.
I look forward to your comments. In the meantime I'm busy working on the bike and doing some farkeling. Next up is a clear windshield, I could use some suggestions as to manufacturers.
If you've stayed with me this long you know how much I share the appreciation for what I consider to be a most under appreciated motorcycle. All I want to do is to get her running smoothly.
Thanks!
Questions, questions, questions..........
Regards,
Randy
Randy
Re: Questions, questions, questions..........
Sir (unknown),
first of all you may want to get yourself the service manual: http://www.carlsalter.com/bmw-service-manuals.asp
Secondly if the bike came from a dealer wouldn't one expect that the bike was fully serviced (fluids, synch, etc)? With regards to the weak indicator lights maybe change the bulbs and clean the contacts? The starter may also require some cleaning and greasing. A replacement is however cheaply available (valeo starter).
The BMW gearboxes have always been kind of special. The first series (upto late 1997) had a common gearbox failure built in but same could eventually also happen in later gearboxes (gears popping out). A repair is costly! Pre-loading the shifter is generally a good idea and leads to smoother shifting.
Suggest you keep reading in this forum as you will find hints/solutions for almost every problem.
Brgds
Oliver
Brgds
Oliver
I did this long ago.omg1010 wrote:Sir (unknown),
omg1010 wrote:Secondly if the bike came from a dealer wouldn't one expect that the bike was fully serviced (fluids, synch, etc)
I confirmed with the dealer that this isn't their practice unless the bike in question appeared to have been poorly maintained. That isn't the case with my bike.
The dealer replaced the neutral light bulb prior to my leaving the lot but there was no improvement. One might think that the mechanic would have inspected the contacts and/or noticed any degradation in the connections but I'll check it myself.[/quote]omg1010 wrote:With regards to the weak indicator lights maybe change the bulbs and clean the contacts?
Thanks for the tip.omg1010 wrote:The starter may also require some cleaning and greasing. A replacement is however cheaply available (valeo starter).
A previous post in another forum mentioned my having lurked here for quite some time plus I've done a fair amount of searches for specific issues. Regardless, I appreciate that you took the time to offer your suggestions.omg1010 wrote:The BMW gearboxes have always been kind of special. The first series (upto late 1997) had a common gearbox failure built in but same could eventually also happen in later gearboxes (gears popping out). A repair is costly! Pre-loading the shifter is generally a good idea and leads to smoother shifting.
Regards,
Randy
Randy
Mornin Randy,
it seems to me you already have the answers to all your questions since you have been around in this forum for quite some time. Good luck with your bike. And with regards to the dealer selling used bike it seems to me that we have a different understanding of what duties that dealer should fulfill. In our part of the world a used bike sold by a dealer comes fully serviced (if not having been serviced prior to arriving at the dealer).
Brgds
Oliver
Brgds
Oliver
