self canceling turn signals
guzzi two
My 2005 Rockster seems to have self canceling turn signals.After 2/10 mi they turn off,at stops they will blink all day long.My dealer says that my bike does no come self canceling turn signals and that sonething is wrong.
Bike is stock with no options except for heated grips and centerstand.
Antbody else have this on their Rock??
They All Have It
Your dealer obviously doesn't know what he's talking about. All Rocksters have self-cancelling signals, though you'd never know that by reading the manual. I believe they shut off on the basis of a combination of time/distance, not how hard you press the button.
2003 R1150R Rockster
Guest
Rockster does have self-cancelling signals. But I think that it's dependent on the angle of the turn AND the speed (more than likely RPM), and the time as well. I don't think that distance is involved.
On a very tight turn (like a U-turn), the signal goes off as soon as I straightened out the bar. The signal goes off quickly when I get the RPM up high. I've tooted along for a good length of distance with the signal still on because my RPM/speed was low. The signal does time itself out, but that takes a long time. Long enough for me to cruise easily in second gear for a couple of blocks.
fallingpines
I have a Roadster and am very suprised that it does not have self cancelling signals (basically the same bike, right?). I know that I can get an aftermarket unit (Kisan Signalminder) that works, but am warned that because it also turns the signals into running lights that the extra current draw can mess with the anti-lock and possibly cause an ABS failure. Anyone know if the self cancelling unit on the Rockster can be fitted to a Roadster? I suspect if so, it will work better with the bikes electronics than the aftermarket unit.
Rockster Self-Cancelling Signals
I read somewhere, that the Rockster's self-cancelling turn signals are a result of the Rockster being equipped with the same guage cluster as the R1100S, with its electronic vs mechanical speedo. Sounded plausible, as the Rock indeed does have the same guages as the 1100S (save for the background colour of the tach, if I recall) but I can't swear to it.
Okay, does anyone know how to turn this feature on and off? Mine has obviously been turned off. I let a friend take a ride on mine last weekend and he spend five minutes riding around with a turn signal flashing because he couldn't figure out how to turn it off. He finally just gave up and rode anyway.
Kisan SM-5 no worries
Fallingpines, I've had the signalminder on since I picked up the bike ( '02 ABS) with zero problems after 22K miles.
Tony
Lifetime #156
2013 K1600GT
Lifetime #156
2013 K1600GT
I'm in the habit of pressing the cancel button manually, even when I haven't turned on the signal in the first place! I guess I'm a little paranoid about blinking my way down the road, so I just tap the cancel button periodically...I know, I know...just a bit of my OCD kicking in!
"If you can't say anything nice, at least have the decency to be vague."
