I just finished working my way through the bleed procedure on my 2003 using the document that's floating around. I started by installing speed bleeders to make it easier to do. Procedure was pretty straight forward- step-by-step from start to finish. A few observations:
- My first surprise was that the reservoirs on my unit were a little different than illustrated in the document. Mine didn't have the 'fingers' to indicate max fill and instead had a white 'basket' at the bottom of the hole. (I filled the reservoir to have a liquid sheen just visible in the bottom of that basket, I think that was similar to when I started the procedure).
-Wishing that there was a different color brake fluid available. It was hard to know when enough was enough. My fluid was last changed a year ago and it still looked clear amber color so knowing when the old was gone and the new was in place was difficult. All in all I pushed 48 oz of new fluid through the entire system, so I'm assuming that I replaced most if not all of the old stuff.
-One of my bleeders on the module was stuck. Aargh...It took a little bit of working around to free it- I got a 7mm deep socket to break the hold and then proceeded with a wrench to do the bleed.
Now that the bleed is done I've observed what appears to be a light wet film on the surface of the module. I assume it's brake fluid but not positive, but what else could it be? It's rainy and cold but I don't think it's condensation, but who knows. Maybe. An air hose blast shows a light film moving on the top of the module. I've cleaned it off but it seems to re-appear. I'm reluctant to put the tank back on until I know for sure what this is, and more importantly a remedy. I've re-checked and snugged all of the bleeder nipples but aren't entirely confident that one isn't seeping.
Questions:
Has anyone else that's been through this had any bleeder issues on the module? How tight is tight when snugging them down. I'm reluctant to apply brute force for fear of stripping the threads in the module.
Has anyone replaced the bleeders on the module with speed bleeders? I won't undertake that now, it's getting too cold in the garage but maybe in the future. Just a thought and wondering if it's been done?
As always, appreciate any input!
And thanks again Steve, you da bomb.
