Aiming Headlight
philm35
Aiming Headlight
Post by philm35 »
I had to pull my headlight while installing new handlebars. What is the accepted technique for headlight alignment?
Thanks,
--Phil
2004 R1150RA (Silver) (Now with Wunderlich Touring Comfort Handlebars)
baltm604
Post by baltm604 »
RTFM!!!
In the user guide that comes with your bike, they describe the measurements for aligning the headlamp while you are sitting on the bike.
DJ Downunder
Post by DJ Downunder »
Moving it is just a push pull thing...it's on rubber mounts.
I just aim mine so the cut off on low beam is level with the bottom of car windows.
In other words..as high as you can without hitting them in their rear vision mirror.
DJ
philm35
Post by philm35 »
I did R my FM! Just the wrong one... Clymer doesn't say a word about it. But you're right, my owners manual has it right there on page 40.
Thanks,
--Phil
bimrluvr
Donating Member #: 429
Post by bimrluvr »
Phil,
I'm expecting a report on both your installation experience and your first impressions of riding with the touring bars.
Enjoy!
#429 (in for life)
'06 Silver R1200RT
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
I try to aim mine so it is shining just below the mirror of the average car during average riding conditions. I want it aimed as high as possible without annoying other drivers. If it is too high or too low, you can just whack it with your hand to adjust.
peterbulgar
Post by peterbulgar »
The owner's manual contains a wealth of information and much of it is useful. IMHO the description of how to aim the headlight is not one of the more useful sections. DJ and Bob described the easiest, most convenient, and most reliable method. Compared to cars motorcycle headllights are affected disproportionately by load - in the past some touring bikes had a knurled knob to easily adjust the height of the headlight when carrying a passenger or luggage. This is one case where I'd ignore the manual.
peter '73 R75/5, '04 R1150RA
HornHonker
Post by HornHonker »
I don't think the American import version has the sharp cut off. Not allowed there.
philm35
Post by philm35 »
I appreciate the suggestion about aiming for the "average window height" or mirror height of a car. I'm sure that would get me in the ballpark, but IMHO a little more precision is required for the legendary motorycles of Germany.
I didn't find the instructions in owners manual too useful either. It calls for parking the bike on a flat level surface 10 meters away from a wall, and hitting a specific measured spot. The bike must be upright, with both wheels on the ground with a rider sitting on it.
Stupid! I don't know about you guys, but my garage is not 10 meters deep, and I can't think of too many places where I can go to perform this procedure that meet those requirements. Plus, the job requires two people... one to sit on the bike and hold it upright, while the other performs the adjustment.
Why not come up with a target height you need to hit from say 3 meters away from the wall, with the bike on the center stand with no load and the rear wheel planted on the ground. Better yet, how 'bout a table that lists target heights under those measurement conditions that allow for riders of varying weights. That way anybody could do the job themselves, precisely and reliably in their own garage. Doesn't that seem like a more "German" procedure? Jawohl!
--Phil
rdsmith3
Post by rdsmith3 »
Phil,
I understand what you want, and I wish that were possible, too. My 10 year old Audi has bubble levels that tell you when the headlights are aimed properly, in both directions. That is useful in a car, and you don't need two people to do it.
However, as others have noted, a motorcycle's headlight is much more variable in its aim than a car's. A passenger on the back, or fully loaded system cases, or even a change in the tire pressure, will affect the aim.
My approach works for me. It may not have the precision you want, but it works.
bimrluvr
Post by bimrluvr »
Keep in mind that the single stock headlight is not very bright to begin with. You may just wind up doing lighting upgrades as your next mod.
#429 (in for life)
'06 Silver R1200RT
rdsmith3
Post by rdsmith3 »
bimrluvr wrote:Keep in mind that the single stock headlight is not very bright to begin with. You may just wind up doing lighting upgrades as your next mod.
Yes, that is very true.
I upgraded to a 90/100 watt bulb, with two relays. It made a huge difference. I still do not get flashed from other cars, even with a headlight that bright.
