Service II Roundup
djwaudio
Service II Roundup
Post by djwaudio »
Hi All,
I am a newb when it comes to servicing the R1100R, but will soon be rectifying that. Normally I have my mechanic do all of my services. Lately I seem to be more endowed with time than bike funds. So its time to dig in!
So the service II involves the following procedures (plus more) that I have questions with since this will be the first time around:
Change Oil in transmission and rear wheel drive at operating temp. - I have heard conflicting reports on what to use. My mechanic has been putting Red Line in there. Any advice?
Check/Adjust valve clearance: Every time the mechanic has done this, he replaces the valve cover gaskets, inner and outer. Is this overkill or is it wise to keep the tradition up?
Renew spark plugs: I have heard that the simple old-style single tip style is best as they help minimize "hunting". Thoughts?
Renew Fuel filter: I'm skipping it this service, it was done at 24k. Is this a pain?
Renew air intake cleaner: To K&N or BMW? Pros cons?
Check idle speed, throttle sync, and CO value: Is the Twin-max the way to go for getting good synch? How is the CO value measured?
Thanks for any enlightenment. I'm starting to enjoy this maintenance piece of the journey. It keeps you thinking bikes when not riding!
:D
Best regards,
Dana
R1100R 75th Anniversary
jon pierce
Post by jon pierce »
In order...............
Always change oils when hot - use only what oil BMW tells you - do NOT use additives.
No need to change gaskets every time.
Use the plugs BMW recommend - change when they recommend.......having said that I have experiemented with others myself on various BMWs but tend to stick with what BMW recommend
Fuel filter is a pain - I understand - it's up to you - it should be ok
Air filter - again stick with BMW origonal
You do need to check / adjust balance of throttles - Twin max is popular - I have used Davida vacum gauges for the past 16 years with no problems. You need a gas analyser for Co, here is a clue if it needs looking at.............how blue are your pipes? Do you have blueing on the inlet side of your centre silencer? If so your mixture might want a bit of enrichment - best have BM do it. Ideal pipe blue is mainly on the first bend out of the cylinders - if it extends much further back have it looked at. This answer is also dependant on where you are and what year bike you have...........do you have a cat? do you have a dog?, sorry - couldn't resist! If you have a cat then the mixture should be adjusted by ECU. Some mid 1990 European machines have not cat and can be adjusted by hand.
Oh, I know it seems that I always say do what BMW say but they DO KNOW what they are doing. Besides - if you fit something non standard and an issue should arrise you never know if what you fitted is causing the problem. Remember we are dealing with an air cooled, low revving two cylinder motor with a seperate clutch and gearbox, simple straight forward oils are all that is needed. I know there have been reports of transmission problems - the thing is you never hear reports of good transmissions! The amount of 'troublems' encountered by owners is VERY small.
Everyone is entitled to my opinion!
bmwdave52
Post by bmwdave52 »
Fuel filter is a pain--true to a point but very doable. Be careful not to scratch your tank so put padding down.
Just take it slow and it comes out nice. I replaced the original clamps with FI clamps. More peace of mind. Use a new gasket.
For the last four years I have used Amsoil 75w-140 in the tranny and 75w-90 in the final. Also, 20w-50 racing oil in the engine. All oils are "Series 2000" lubricants.
No problems.
