now I hear everything,,,a metal oil filter, something like a K&N filter, you removed it,,wash it and put it back!
<http>http://scottsonline.com/indexframe.html#feedback.htm
metal oil filter-
solitario11
metal oil filter-
Rafael
R1150R k4
V-STAR 1100 k6
Valley Cottage NY
R1150R k4
V-STAR 1100 k6
Valley Cottage NY
I've been warned off of this and similar products by a number of knowlegeable mechanics and engineers. The root of the problem is that the claims exceed performance by a considerable margin. Simply put, the filter doesn't work as advertised. The advice I got was to stick with the OEM filter.
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
That reminds me of the toilet paper filters that were all the rage back in the '60s. Remember those? I had a friend in grad school who put one of those things on a new Mercedes and didn't change the oil or t-paper for thousands of miles. Also neglected to check the oil level. Sure enough, the engine fried and the warranty was void.
HornHonker
OIL FILTER
AC DELCO PF-53 CAN BE USED WITH NO PROBLEMS, PER A MODERATOR.
pf-53
I tried to put the BMW oil filter wrench on AC DELCO PF-53 at a local auto parts store. It was too small(the filter). So I am going for the K&N, it has a nut tack welded to the bottom of the filter for install.
