Adjusting Headlights
whiteknight
If I want to raise the low-beam, do I turn the hexagonal thumb screw? Seems simple enough. I can tilt the entire assembly up or down, but I tried to turn the thumb screw with a lot of resistance and it doesn't seen to raise or lower the beam.
whiteknight
Right On, Big Papa!
Thanks for the know-how. I figured erroneously that each thumbwheel moved each beam up or down.
