Driving Lights
Driving Lights
Hi just purchased a new r1200r and expect delivery some time next week.
Looking for recomondations for adding driving lights on a non ABS model. Does BMW specify a maximum load that the battery/alternator can support for all accessories including lights?
07 R1200R
Bill, thanks for the email with the pics. The lights look great!
As far as I know you have to host the images at a separate site. If you have the time you may want to try http://imageshack.us/ I haven't used the service but see that some other members do. I would think its pretty straight fwd.
2007 R1200R (now sold)
2008 Sprint ST
2005 VRSCSE
2008 Sprint ST
2005 VRSCSE
Driving Lights
Mark,
Thanks for the tip. I'll go take a look at that web site you suggested. I would really like to be able to post a few photos to this forum. Thanks again!
Wkincaid
'07 R1200R
MOA
AMA
kg4tlr
'07 R1200R
MOA
AMA
kg4tlr
edward1981
Can anyone comment on the long-term reliability of the Moto Lights?
I have a set of Lazer Stars on my other bike, and they seem well made, but I can count on replacing the lamps once a season and the sockets about every other year.
I think both lights use the same kind of MR-16 lamps, and I'm wondering if they both have the same problems.
Neil,
I don't remember what the MotoLights people say, but I went two years without replacing them on my 04 RT. So when I got rid of the RT I had a new set of the Moto's installed on the R1200R. If you go to their web site I think you may find a life expectancy of the bulbs and if I remember correctly, it seems like a fairly long time. Hope this helps.
I also have the MotoLights. I have had the same set on 4 different bikes. After putting them on the R1200R I switched from 35w to 50w bulbs and noticed alot of oxydation on the old 35w bulbs but figured it was because they were 8 or 9 years old. After about 2000 miles on the new 50w bulbs I noticed some condensation on the inside of one of the lenses. After closer inspection, I found the reflector completely cracked away from the bulb and cracked in half. Still held together by the white silicon ring around the outer lip of the lamp. And it was still working and continued another 2000 before I could get it changed.These lamps are tough. I did notice my old friend Mr. Oxydation on both of the lamp reflectors. I believe these lamps produce so much heat that it is very hard if not impossible to stop them from drawing moisture inside the housing. I am now trying a 50w GE Edison bulb with a sealed reflector and would be impossible for water to get to it. They look good, are brighter, have a wider pattern and will let you know if I encounter any problems.
See you on the road.
Dirty Red
Dirty Red
11 F800R
Hers : 03 F650CS
PRIORS :07 R1200R
04 K1200GT/01 K1200LT/97 R1100RT
88 R100RS mono/88 K75
Hers : 03 F650CS
PRIORS :07 R1200R
Re: Driving Lights
I have bought the Moto Lites, but not installed them yet. and would like to see the pics as well.wkincaid wrote:Mark,
If I get done first, I will post my pics.
