Coil tubes
gel9001
Coil tubes
Post by gel9001 »
wow, I just replaced both of mine on my 2004 twin spark and frankly I am blown away by all the problems fixed and increased power, idle is back to normal, no more hesitation, runs, sounds better at all rpms. The bike has 40K miles, but its been running bad for like 2 years. Breaks my heart to think that I've been mistreating my engine for so long, counting on the spark of the secondary plug. I paid like 90. from Chicago and would recomend replacing these to anyone who's engine not running as it should. Also note, that they are different from the original units. Apparently BMW upgraded without sending a recall.
I'm back in love with my Roadster for the second time.
Regards,
Gene
jas
Re: Coil tubes
Post by jas »
Do you have the part numbers?
2004 Roc.
maduko
Donating Member #: 735
Bosch Coils
Post by maduko »
Seems like almost every German car with direct ignition has had coil problems too.
Bosch just can't seem to get these right.
RVC7
Re: Coil tubes
Post by RVC7 »
Anybody care to explain to us nubes what these are and what exactly they do?. Thanks so much!
'02 Piedmont Red
gel9001
Re: Coil tubes
Post by gel9001 »
Part # 12 13 7 680 644 about 90 each from Chicago BMW, I recommend replacing them to anyone with engine problems. The bike has so much more power that I've had to change the way I change gears, and power that jolts my neck back.
I took apart the old ones and there was no oxidation, but apparently the problem is within the coils. The new coils have a grey ring around the top of the tube, definately a BMW upgrade yet no recall for the other old ones. Coat the insides with dialectric grease.
Good Luck and do this!!!
Gene
priapismic
Re: Coil tubes
Post by priapismic »
You talkin' 'bout these coil sticks from the primary spark plugs? Cause if there's a coil for the secondary plugs, I don't know where it is. Enlighten us, please ...
gel9001
Re: Coil tubes
Post by gel9001 »
yep thats what I'm talking about, replace them
R4R&R
Donating Member #: 293
Re: Coil tubes
Post by R4R&R »
priapismic wrote:Cause if there's a coil for the secondary plugs, I don't know where it is. Enlighten us, please ...
Yes, there HAS to be a coil for all spark plugs. 12VDC is not enough voltage to arc across the gap of a sparkplug in a compressed atmosphere. The secondary coil is up under the fuel tank (IIRC). The secondary plugs share one coil.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
brem
Donating Member #: 621
Re: Coil tubes
Post by brem »
Doubtless there are even more threads on here on the subject, but I replaced both coils last summer and a fair bit of that detail is here:
viewtopic.php?f=2&t=14538&st=0&sk=t&sd=a
It's shockingly simple once you buy the coil-puller. The BMW plastic one sucks but can be made to work.
2004 Citrus Rockster
