How will BMW hide the radiators on the next roadster?
- Grey Thumper
I assume it'll be a while before we see a water-cooled R1200R. The naked/standard variant of the boxer line is usually the last to go into production. But I'm wondering when that time comes, how will the radiators be hidden (and will they need to be much larger than the oil-cooling radiator thats currently on the front/lower section of the R1200R's engine?
Edition 80 #1803
Re: How will BMW hide the radiators on the next roadster?
Probably in the same way the radiators were disguised in the Rockster, inside fat "cheeks" at the front of the tank. Because the tank shape will have to change, I'll bet we also see the fuel strip replaced by a float.
David Brick
Santa Cruz CA
Santa Cruz CA
Paul-from-VA
Maybe similar to the F800R, or maybe....there won't be an R
Paul
I don't think that's likely. The F800R has conventional telescopic forks with no Telelever, so there's room for a single radiator up under the steering head. An R wethead would (presumably) have a Telelever like the current bikes, in the same space. A radiator wouldn't fit.Paul-from-VA wrote:Maybe similar to the F800R...
That would be a shame....or maybe....there won't be an R
David Brick
Santa Cruz CA
Santa Cruz CA
- Grey Thumper
This seems to be the most feasible solution, given that either BMW and/or the market will insist on telelever suspension. I actually find the Rockster radiators a more elegant design than the current single radiator on the R1200R. But the latter design was made necessary by (I assume) the need for a larger radiator. And the radiators on the GS seem even larger in total area. Anyway, BMW have a few more years to work out a solution. I'm optimistic.dbrick wrote:Probably in the same way the radiators were disguised in the Rockster, inside fat "cheeks" at the front of the tank.
Edition 80 #1803
Seems like they aren't going to hide it at all, but put it right up front.
http://ultimatemotorcycling.com/bmw-unv ... ary-model/
John Smutny
2000 R1100R
2000 R1100R
That's not the water cooled engine though..
My opinion of the R nine T remains: meh.
This bike is not for longer trips,as I can see
Seems they took an R12R and removed most of the versatility. Looks like an occasional Saturday afternoon ride.deilenberger wrote:My opinion of the R nine T remains: meh.
Kevin Huddy
Intrepid Incompetent
Canyon Creek, MT
Canyon Creek, MT
- Grey Thumper
Exactly. I think it's pretty good looking actually, but way too impractical. I'd only buy one if there were a bunch of other bikes in the stable (as if that would ever happen). On the other hand, the R12R is pretty much all the bike one could ever need.MTBeemer wrote:Seems they took an R12R and removed most of the versatility. Looks like an occasional Saturday afternoon ride.deilenberger wrote:My opinion of the R nine T remains: meh.
Edition 80 #1803
