How will BMW hide the radiators on the next roadster?
Grey Thumper
Post by Grey Thumper »
I assume it'll be a while before we see a water-cooled R1200R. The naked/standard variant of the boxer line is usually the last to go into production. But I'm wondering when that time comes, how will the radiators be hidden (and will they need to be much larger than the oil-cooling radiator thats currently on the front/lower section of the R1200R's engine?
Edition 80 #1803
dbrick
Donating Member #: 902
Re: How will BMW hide the radiators on the next roadster?
Post by dbrick »
Probably in the same way the radiators were disguised in the Rockster, inside fat "cheeks" at the front of the tank. Because the tank shape will have to change, I'll bet we also see the fuel strip replaced by a float.
David Brick
Santa Cruz CA
Paul-from-VA
Post by Paul-from-VA »
Maybe similar to the F800R, or maybe....there won't be an R
Paul
dbrick
Post by dbrick »
Paul-from-VA wrote:Maybe similar to the F800R...
I don't think that's likely. The F800R has conventional telescopic forks with no Telelever, so there's room for a single radiator up under the steering head. An R wethead would (presumably) have a Telelever like the current bikes, in the same space. A radiator wouldn't fit.
...or maybe....there won't be an R
That would be a shame.
David Brick
Santa Cruz CA
Grey Thumper
dbrick wrote:Probably in the same way the radiators were disguised in the Rockster, inside fat "cheeks" at the front of the tank.
This seems to be the most feasible solution, given that either BMW and/or the market will insist on telelever suspension. I actually find the Rockster radiators a more elegant design than the current single radiator on the R1200R. But the latter design was made necessary by (I assume) the need for a larger radiator. And the radiators on the GS seem even larger in total area. Anyway, BMW have a few more years to work out a solution. I'm optimistic.
Edition 80 #1803
smutny
Post by smutny »
Seems like they aren't going to hide it at all, but put it right up front.
http://ultimatemotorcycling.com/bmw-unv ... ary-model/
John Smutny
2000 R1100R
That's not the water cooled engine though..
My opinion of the R nine T remains: meh.
Steve H.
Post by Steve H. »
This bike is not for longer trips,as I can see
MTBeemer
Donating Member #: 1043
Post by MTBeemer »
deilenberger wrote:My opinion of the R nine T remains: meh.
Seems they took an R12R and removed most of the versatility. Looks like an occasional Saturday afternoon ride.
Kevin Huddy
Intrepid Incompetent
Canyon Creek, MT
Grey Thumper
Exactly. I think it's pretty good looking actually, but way too impractical. I'd only buy one if there were a bunch of other bikes in the stable (as if that would ever happen). On the other hand, the R12R is pretty much all the bike one could ever need.
Edition 80 #1803
