Sport Shield Install
I just bought a used BMW sport shield.
I don't have instructions and I can't figure out where exactly the brackets mount. I think I have the top ones figured out, but the lowers don't seem to have anywhere to go.
If anyone has instructions or could even post pictures of how thier brackets are mounted I would appreciate it.
The sport screen uses the same supports as the touring screen. The big ones at the top that attach to the 'hard to reach' spot under the triple tree and the lower, smaller ones that attach to the inside of the turn signal stalk... the turn signal must come off to get the supporting bracket in there behind it. Then the windshield lower support attaches to that bracket piece.
If you need directions, I have a sanned copy somewhere here. PM me with an email address and I'll shoot it to you.
Thanks for the reply. I do believe that I have the sport shield. I don't know how to post pictures, but here is a link to the item on the Sierra BMW site. Hope it works.
http://www.sierrabmw.bigstep.com/item.j ... ID=1174432
It has two sets of mounts. One high and one low. The high ones are mounted like the ones in your picture. I have the longer bolts. Those I had figured. The others are lower and look like they wrap around the plastic pieces on either side of the headlight. They have a plate with two holes on the end, but I can't see any existing screws that these would connect to. [/img]
Since the upper bolts are a real pain to get to, even with a short ball Allen wrench, you might do what I did - go to a nuts and bolts store and buy the same threaded bolts with a hex head. Still not exactly easy but much better to get on and off.
I switch from the speedster shield to the sport shield every fall, so I have put them together a few times!
Vann - Lifer No. 295
- Dr. Strangelove
Great idea!wncbmw wrote:Since the upper bolts are a real pain to get to, even with a short ball Allen wrench, you might do what I did - go to a nuts and bolts store and buy the same threaded bolts with a hex head. Still not exactly easy but much better to get on and off.
I am getting ready to remove my always-working-the-wellnuts-loose touring screen and replace it with the Tall 380mm Windshield.
I have been unable to get the 6mmhex bolts loose and I am about to go after them with a pliers (taht's desparate!). The hex bolt is a terrific thought. How's that working for you?
'09 Schwarze Blanche DuBois
I have made the transition a few times since I changed the bolts and it works much better for me. Still not easy but better. I have seen some flexible headed wrenches at Sears and thought to give one of those a try. Might make it even easier!
- jimpastorius
I have an extra mounting kit for the fly screen...$25 plus shipping... PM me if you are interested.artattack wrote:Got what I needed from Boxer.
It appears I am missing a couple of parts. Brackets to be exact that mount to the turn signals.
I'll try contacting the guy I bought it off of and see if he has the parts, but I may end up buying a whole mounting kit.
Thanks for the help.
I don't think that works for the Sport screen.jimpastorius wrote:I have an extra mounting kit for the fly screen...$25 plus shipping... PM me if you are interested.artattack wrote:Got what I needed from Boxer.
2002 Atlanta Blue
Lifetime Member #74
2002 Atlanta Blue
Lifetime Member #74
- Dr. Strangelove
Do you recall the head size of the bolts that you switched to? 8mm? 10mm?wncbmw wrote:I have made the transition a few times since I changed the bolts and it works much better for me. Still not easy but better.
getting any wrench in there will be tight
JOhn
ha ha ... I am a sucker for stuff like that. I just bought some racheting box wrenches at BJ's wholesale club. I believe it was my wife's fault for sending me to get groceries.wncbmw wrote:Bolt head size on mine is 13mm. Yes, it is tight! Tiny turns! But better than the Allen wrench! I am going to try some of those shiny new racheting box wrenches or flexible head wrenches I saw at Sears this weekend!
2002 Atlanta Blue
Lifetime Member #74
2002 Atlanta Blue
Lifetime Member #74
- Dr. Strangelove
