I just bought the Hepco-Becker rack, and I'm hoping someone can help me out.
I bought the BMW side-rails awhile back, but I've never had the BMW rack. From what my pidgin German and Google tells me, I need to have the 'original' screws to mount the rack to the BMW handles. I know I didn't get any screws with it, so that's all I can think of.
Can anyone confirm this, and if so, anyone have a part number for the BMW screw kit (or a size I can get form the hardware store)?
The second question is about the mounting. I found screws that were about the right size and test-fit the rack just getting the nuts hand tight. The rack seems like it's too narrow for the rails by 1/4" or more on each side. Are there spacers involved or do I just torque it down? I'm a little worried about breaking the plastic rails.
Pics:
http://www.argolis.org/matt/pics/Pub1/
Hepco-Becker Tail Rack Install, help!
Go Sabres!
ScooterCop
I got a pair of their engine crash bars and had to deal with German instructions. I found this site to be helpful:
http://translation2.paralink.com/
Rick
2003 R1150R: Silver
Lifetime Member #585
2003 R1150R: Silver
MikeCam
- Centurion Moderator!
Oops, answered your other post first...
Here.
Parts Fiche extract:
01 46632329649 left case holder BUY 1 $54.00
01 46632329650 right case holder BUY 1 $54.00
02 46547654765 luggage carrier, white al BUY 1 $99.00
03 07129903309 screw (M6X30) BUY 4 $4.50 (rear rail)
04 46547654763 fillister head screw(M8X40)BUY 2 $3.00 (front rail)
05 31422310341 flat washer BUY 2 $0.75
06 07129903329 screw (M6X25) BUY 4 $4.00 (top rack)
07 52537686463 badge (D=27MM) BUY 1 $8.00
08 46547655724 plug BUY 4 $2.00
08 46547655725 cap BUY 4 $2.00
You need part #6. Check, if you can for fine vs medium vs coarse threads. I believe it is 1.25 threads you need. But it might be 1.00 threads.
The slight offset of the rails to the rack is not a problem. Simply loosen the rear frame bolts slightly, then fit everything loosely, then tighten everything evenly (to frame and rack at same time).
Here.
ScooterCop
