Holy cow...while changing the rear shock I accidently bumped into the rear master cylinder and BROKE off the plastic fitting that goes to the fluid reservoir. BMW does not sell the plastic fitting...only the complete master cylinder. $128.00
1 where can I buy this fitting?
2 why is such an important part made of plastic anyhow....
Thanks!
r850r rear master cylinder
Re: r850r rear master cylinder
You might want to try the R1100R section, it's a very similar bike and has more traffic.jacksgp wrote:Holy cow...while changing the rear shock I accidently bumped into the rear master cylinder and BROKE off the plastic fitting that goes to the fluid reservoir. BMW does not sell the plastic fitting...only the complete master cylinder. $128.00
Thanks!
Go Sabres!
What R1100R section?
Also..where can I buy steel brake lines...Thanks
Railbender
The R1100R section is 3 above this one.
For SS brake lines try;
http://www.cyclebrakes.com/html/custom_lines.html
Beemerboneyard has a used rear master cylinder for $60.00;
http://www.beemerboneyard.com/34312314547.html
Railbender...thanks for the info!
I was going to order the master cylinder from beemerboneyard but I found another site called EngelandMoto.com and paid $30.00. They have an asking price or "make offer" feature and I was able to get it for less. I installed it today and I'm back on the road.
